How do i hook up a 4 channel amp to 2 12" subd?
Username: Smokeythabandit
i have a hitachi four channel / two channel/ 3d system bridgeable hi-power amp it is 100x2/50x4/100+50x2 what would be the best way to hook it up on 2 rf 12" subs?
Username: Jsaudio4
Anaheim, Ca US
HOOK UP ONE SUB TO CHANNEL ONE AND TWO BRIDGE AND THE OTHER SUB TO THREE AND FOUR MOST OF THE TIME THE ITS ONE POSSITIVE OF ONE CHANNEL AND NEGATIVE OF THE OTHER CHANNEL. YOU MIGHT NEED A CROSSOVER IF THE AMP IS ONLY A HIGHPASS OR FULLRANGE IT WILL ONLY PLAY FULLRANGE THROUGH THE SUBS
Username: Tjmutlow
Post Number: 2198
the only way you can bridge that amp if it is a dual 2 ohm sub or single 4 per pair of channels.
