Alpine type r's
Username: Hawk44
I think i can get my 12 type r's to run on 850 rms per sub. w/ a huge amp. If u think this is possible contact me and help me a little. thanks
Username: James1115
Ct
Post Number: 5906
anything is possible if you have control over the loudness, if you are a spl head and just crank it all the time you will cook thems with that much power in a daily driver application.
Username: Rob_preg
Royal oak, Michigan United states
Post Number: 337
"u think you can give your type-r 12's 850 rms per sub." what exactly is making you "think" this. they may be able to take it for a lil while, but remember your giving them almost double their rms, and unless you know for sure that sub can take well beyond its rms, you may end up ruining your subs. also, "is it possible and can you help me"?? like the post before this, anything is possible, and its just a bigger amp, nothing different that you have to do compared with what your currently running, besides possibly upgrading your wiring and alt if its too much power for your car to handle. otherwise, good luck.
Username: Sweet_subs
Memphis, Michigan Usa
Post Number: 27
why would go go and buy some expensive amp that puts out 850 rms pre channel and get some good subs why not just save ur money for a little bit and get 2 really good jl audios or somehting that will hold up to 850 rms.
Username: Goatin
Ohio U.S.A
Post Number: 1288
I have heard of people running 700RMS with great success But I think 850 is a bit much if you plan playing them for more than 5-10 min.
Username: Rovin
Trinidad & T...
Post Number: 8023
agreed ^^^ ......
Username: Juliob
Santo DomingoDominican Re...
Post Number: 663
turn the gain LOW
Username: Goatin
Ohio U.S.A
Post Number: 1307
Then you will risk clipping the subs if the gain is set incorectly.
It's called a Gain dial not a Volume dial. :-)
