Cold cranking amps
Los Angeles, CA USA
Post Number: 4014
what does that mean? i see that on my yellow top its 750 cold cranking amps.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 7379
Cold cranking amps (CCA) is the amount of current a battery can provide at 0 i½F (-18C). The rating is defined as the amperage a lead-acid battery at that temperature can deliver for 30 seconds and maintain at least 1.2 volts per cell (7.2 volts for a 12-volt battery). It is more a demanding test than those at higher temperatures.
Los Angeles, CA USA
Post Number: 4015
thanks chauncey. i can always count on you.
Post Number: 7383
glad to help
Username: B101
Queen City, NC USA
Post Number: 3090
yep, what CB said!!
Thats the deffinition!
Post Number: 7418
I use this site for alot of stuff, its really good
http://en.wikipedia.org/wiki/Main_Page
