Volts
Username: Iravemp
Can I run 8volt hu into s 4volt max amp..
I think It cant be done..???
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 7314
what kind of amp is it???
Username: Fandim
Reno, Nevada United State...
Post Number: 1080
Yes, easily. Just make sure all your amps are set to the same voltage, and be extremely sparing with the volume control. you'll clip the hell out of it even if it's set to it's lowest sensitivity, if you turn the volume up too much.
Username: Iravemp
Post Number: 9
The amp is jbl 1200.1
So the answer is no?
Username: Antiwhy
Sioux Falls
I plan on running 1K class a/b watts RMS. I'm going to upgrade the "Big 3" and replace my battery with a red top. My alternator is 105 amps,will that be ok?
