Need amp!
Username: Ziemer_07
ok i have 2 ma audio subs 121QS 300/350 watts RMS dual 4 ohm voice coils....can someone suggest and amp that will put out 300 watts RMS to both subs....do i need one that says 1*600 watts RMS @ 4 ohm...? what would it have to say for a 2 channel amp?
Username: Logan__tille
Hamilton, Indiana United states
Post Number: 214
budget?
Username: Ziemer_07
$150-250
Username: Thomas_g
NM
Post Number: 967
U will need 1 that says 300rms X 2 @ 2ohms or 1ohm stable bridged so 600 X 1 @ 1ohm or 600 X 1 @ 4 ohms.
Username: Johammbass
Cork, Cork Ireland
Post Number: 232
You need a mono block that gives 600Wx1 at 4ohms or 600Wx1 at 1ohm.
Or a 2ch amp that would give 600Wx1 at 4ohms when bridged.
These would work fine:
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=475
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=186
Then this one would work great for the money:
http://cgi.ebay.com/PPI-PRECISION-POWER-PCX2200-PCX-2200-NICE-orion-jl_W0QQitemZ 9733920765QQihZ008QQcategoryZ18796QQrdZ1QQcmdZViewItem
Username: Antiwhy
Sioux Falls
I bought this amp a few months ago it works great. Its even cheaper now. I have seen it at A1 audio for $425 http://www.ikesound.com/product-product_id/3379
