When hookin up an amplifier...
Username: Dustin3
Tigard, Or U.S.
Post Number: 1305
when u ground it, do u usually use somthin to hold it down to the bare metal??
and wut are the gray wires? they are pos and neg somthin, because they have a red and black tape on them... wut is this and where does it go?
Username: Jirvin_82
Drill a hole and use a bolt and nut to hold your ground cable to bear metal. I have never seen an amp with gray wires. Are they coming out of the amp?
Username: Dustin3
Tigard, Or U.S.
Post Number: 1329
I got the prob. fixed.
wouldnt it be bad to pinch the ground wire like that?
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 2274
it can be bad to pinch any wire. that can create a voltage drop and cause problems.
Username: B101
Queen City, NC USA
Post Number: 2980
ground is the wire u least have to worry about.. so u dont even need insulation on your ground wire, unless u are runing it side by side with positive...
I would'nt worry too much about pinchin the ground, but I would worry ALOT about pinchin any other wire...
