Problem?????????
Username: Fbmbiker79
Shawano, Wisconsin United states
Post Number: 19
i have a legacy blue diamond amp and its the 2400watt 2 channel i wanted to bridge it with 2 subs but when i do i blow 1 out of 2 fuses on the amp EVERYTIME WHATS WRON"???????!!!!!!!!!!! SHOULD I BU BIGGER AMOP FUSES IT CAME WITH 15AMP FUSES
Username: Carguy
Post Number: 5565
First off, that brand does not make quality products.
If the fuses are blowing, then the subs are too low in resistance.
If you do the math, 15A fuses can not give 2400w of power.
Double check your amps manual for proper bridging.
