How to get the best Bass
Username: Bayhyphysounds
The City 415
I just bought 2 12'' Kicker L7's 4ohm's 1500 watts each. How many watts am I going to need to get these sub's to really hit hard??? Please note: I would need to know # of watts, & either 2ch. or mono amp.
Thanks............
Username: Van_man
Boston, MA
Post Number: 429
Monos, feed them @ 1000wrms each, + or - 200wrms.
Those subs are 750wrms each. but will take over 1000. Is you can find a good amp that puts out like 2000 at 2 ohms or 2 amps that push 1000 at 2 ohms. Run a minimum of 800-900 each to each sub and they will slam.
Username: Goatin
Ohio U.S.A
Post Number: 1278
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13490
Get 2 of these. :-)
The City 415
Right on....... thanks again!
Username: Van_man
Boston, MA
Post Number: 432
RMS on those is only 400wrms.. You would need 6 of those to power those subs well. Again feed them @ 1000 real watts each. Try looking for something like this.
http://cgi.ebay.com/2-1000d-watt-amp-memphis-amplifier-car-amp-power-amps_W0QQit emZ9734049431QQcategoryZ18797QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Username: Van_man
Boston, MA
Post Number: 433
Sorry, my bad, I see the ones Rave'n posted were 800wrms @ 2 ohms. They would work well.
