Kicker amp
Username: Big_fletch
Newport, Ar, Ar United states
Post Number: 21
does anyone have a kx 2500 watt amp they want to sell or willin to sell? and what website can i find one of these amps to be on thats pretty cheap?
Username: Ctmike
Ct.
Post Number: 699
cheapest on ebay:
http://cgi.ebay.com/KICKER-KX2500-1-2500-WATT-MONOBLOCK-AMPLIFIER-MONO-AMP_W0QQi temZ9731825135QQcategoryZ79829QQrdZ1QQcmdZViewItem
Username: Goatin
Ohio U.S.A
Post Number: 1213
Ebay.
If your looking for cheap get the Orion 2500.1 WCC Edition its like 450 new and is a great amp.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 7251
do u need an amp thats 2ohm or 1ohm stable???
Post Number: 23
the subs are 2 ohm so prolly 1 ohm but im gonna be pushing both these subs with an amp 2500 kicker
Username: B101
Queen City, NC USA
Post Number: 2990
if the subs are 2ohms and u plan on using 2 2ohms.. u need a 2ohm amplifier, get the Kicker...
Username: Illwill577
Post Number: 67
Tyler i got that same amp hooked up to 2 15" l7s wired @ 2ohms. sh*t slamms hard. i got my amp for like 550$ shipped new on ebay.
Post Number: 47
what do u have your subs in? mine is gonna be in a escalade
Post Number: 48
did u haft to raplace your factory alternator cuz u got the 2500 watt amp? and what are u hittin on db?
Username: Gage
Post Number: 296
what is with people always asking how many db's... yes you will need an ho alt and its too hard too tell you the exact dbs
Post Number: 50
hey gage calm down i mean all im tryin to do is put asystem in my vehical u dont have to get all pissy im not wantin spl damn
Username: Ctmike
Ct.
Post Number: 701
again, you should really read this site,
http://www.bcae1.com/
and yes you will need a ho alt. for that much power. look under the accesseries forum for the thread "group buy in may" and order a ho alt. from excessive amperage, but hurry cause you only have like 2 days left.
