Please suggest me an amp for powering a pair of Type r subs without having any change in the electric system. If I buy an amp having power of 500/1 wrms, can it be able to pump those subs properly??
yeah but iv seen a picture of amans car and its is a smaller sendan type car not a big truck so the stock alt isnt giong to be huge probly tops 100amps so i wouldnt put more then 500-600rms tops on it
Hello, you mean that an amp having a power of 600wrm will be able to run on the stock alternator? Will that pump the r type subs properly? what acould be the configuration for doing so?
get a kicker1200.1 and an extra battery and a battery isolater theres no hell in way a jl 500/1 will run 2 type R's dont worry about an alternator yet an extra bettery is just fine as the amp goes straight to the battery anyways when it reaches the limit of the alternator
