L7 box custom
Username: Illwill577
Post Number: 68
yo i was just wondering if this box would be ok.
box is for 2 15" l7s
Port Type: Slot Port
Port Tuning: 37 Hz
Port Dimensions: 16.125 x 1.875 inches (Height x Width)
(port length is not displayed)
Port area: 30.23 square inches
Number of Ports: 1 (per chamber)
Net Internal Volume: 3.5 cubic feet per subwoofer
Port Volume: 0.25 cubic feet (includes displacement of port materials)
Total Internal Volume: 3.75 cubic feet per subwoofer ($35.00 extra)
Number of Terminal Cups: 1 per subwoofer
Front Baffle: Single-Layer Front Baffle - 3/4" Thick
Box Dimensions: ** Please ensure that this will fit in your vehicle before completing your order **
39" (w) x 24" (d) x 17.625" (h)
Cutout diameter: 14.125 inches - square
Mounting Depth 8.25 inches (maximum)
i had to make port like that cuz sh*t wouldnt of fit in my caddy the width. just wondering if that would be ok.
Post Number: 69
btw its from klausaudio.com
Username: B101
Queen City, NC USA
Post Number: 3010
it should get loud, in that box... but u can build a stronger box by yourself... will even sound better and deeper...
Post Number: 70
true i was thinking about that but i dont got no tools or now where to build at. kicker recomends like 3.0 cu for ported. i couldnt do alot i was trying get 4.0 or more but trunk space is limited. just was making sure that this box would be "ok"
Username: B101
Queen City, NC USA
Post Number: 3057
it will be OK..
but its still a prefab box..
