Sound deadning
Username: Sw9152
Michigan
Post Number: 754
where is a good place to get it and what is a good brand? sheets are prefered but will do paint on if its better and cheaper. i will need only enough to do the rear hatch door on my ford explorer suv.
Username: Brycew7
B.C., B.C.
Post Number: 17
i've seen some on ebay, companies like dynamat, or Brown bread i hear is pretty good.
Username: Shortysetnies
Rock Vegas, NC US
Post Number: 185
SW, if you want it to look very good this isn't a good idea but putting a couple screws through the back plastic trim into the metal supports works great. I drilled a hole through the trim and support, welded a nut on the back of the support, and then ran a bolt through the hole and that stopped A LOT of rattling. If you paint the bolt to match the back of the truck, it is a lot cleaner looking. hope that made sense.
Username: Stnorris
Eldridge, IA US
Post Number: 177
Edead off of ebay. it comes in 3 different types. Check it OUT!
Username: Tweeker
Post Number: 106
has anyone tried that sound deadning that comes in like a spray can? i was thinking of getting it for those hard to reach places.
Username: Jinster
Post Number: 86
when i was frequenting corvetteforum.com, i couldn't see anything but praises for those spray cans
Username: Alteraudiousa
Concord
Post Number: 808
spray ones suck. They take alot of the liquid to make one good layer. Spray is good for things like corners but for whole planes of metal use the matt.
