Like
What to set amp one the
Username: Mr_kebo
Albertville, Al USA
Post Number: 343
I have the 6500's from eD and an eD NINe.2x amp. what should i set the filter to, lp,full,or hp. if hp what should i set it to?
Username: Dustin3
Tigard, Or U.S.
Post Number: 1262
low pass, becaue ur not going to be using any high freq.
subsonic filter is what ur ported box is tuned to.
LP should be set around 80
Username: Mr_kebo
Albertville, Al USA
Post Number: 344
its a componet set. So there will be some high freqs!
Username: Suleman36
Maryland U.S.A.
Post Number: 3838
Mr Kebo, set your amp to HPF and set the crossover at 12db @ 100hz
Usually 100-125hz is best for components. It will cut out all those low freq that speakers are not suppose to handle. Leave that for your subwoofer.
Set your subwoofer amp LPF to 18 or 24db @ 80hz
That will give you great results and sound better.
Username: Mr_kebo
Albertville, Al USA
Post Number: 345
thanks
Username: Adddisorder
West palm, Florida
Post Number: 267
MO maybe im wrong here but couldnt you just leave your amp crossover on full because it is a component set and has its own crossover for the midbass diver and tweeter?
Facebook
Shop Related Deals
Directory
