Anyone know anything about subs and amps?
Username: Splinter00
ok if you got some experience or anything with subs and amps e-mail me, i need help connecting my sub to amp and i need to find some info on them but i dont no where to look, ill let you know what the problem is,so if you wanna help me just give me a shout at base_ket_balldude@hotmail.com :-)
ok ill just give you guys an idea of what i got here and see if you can peice it all together..
Sub: Kicker Solobaric S10L5:
Speaker Type: Passive
Nominal (RMS) Output Power: 450 Watt
Max (RMS) Output Power: 900 Watt
Response Bandwidth: 24 - 100 Hz
Sensitivity: 86 dB
Additional Features: Dual voice coil
Amp: Planet Audio VX400D
CLASS D MonoBlock Power Amplifier
Max Power (2 Ohms) 600W X 1
RMS Power (2 Ohms) 350W X 1
RMS Power (4 Ohms) 200W X 1
Signal-to-Noise Ratio:100 db
Frequency Response: 25-250Hz
what do i all need as in an amp kit and will these 2 work together? i got a sub box that says 2ohm output on the back, so i have to make my sub a 2ohm will that work with the sub?
will that work with the amp**
Username: Ctmike
Ct.
Post Number: 576
jordan, that amp will work with that sub, just wire it to a 2ohm load, but you will be underpowering that sub by about 100w.
Username: Van_man
Boston, MA
Post Number: 313
What are the voice coils duel 2 or 4 ohm?
yeah, thats what i thought, but it will have to do for now, what would i need for an amp kit? and what size gauge of wire?
4 ohm on the sub
Username: Van_man
Boston, MA
Post Number: 314
2 4ohm coils or 2 2ohm coils?
Username: Van_man
Boston, MA
Post Number: 315
Never mind just look it up here
http://www.crutchfieldadvisor.com/learningcenter/car/subwoofers_wiring.html?view =all
on the box it says: solobaric s10l5 dual 4ohm vc woofer so im not sure, but it sounds like 2 4ohm coils
Username: Van_man
Boston, MA
Post Number: 316
Option 1
http://www.crutchfieldadvisor.com/learningcenter/car/subwoofers_wiring.html?subs =2&impedance=DVC4x2
Post Number: 7
ok thanks, also what do you think about setting all the gains on the amp? should i get someone to do it, or i was reading that if you set them all around 3/4 full it will be ok?
Username: Van_man
Boston, MA
Post Number: 323
turn gains all the way down,Turn your Hu volume to the max position you would normal blair it at. slowly turn up the gain until it starts to distort, back it off a hair and your set. Do not exceed your max volume level once you set it. you could risk ruining your amp, subs or speakers due to clipping.
Post Number: 11
ok, what are the "gains" exactly, on the side of the amp it all says:
Input level: min-max
subsonic: lowest 15 highest 40
input sensitivity with 2 options:100mv-2v or 2-8V
bridged mode: slave or master
Phase: 0 or 180
low pas 50 lowest, 150 highest
bass boost 0-18db
also theres a remote level controller what should i do with that?
can someone point me in the right direction?
