2 12" 2000 chevy sinlge cab Kicker CVR or Infinity
Username: Alexochoa
Tucson, Arizona USA
Post Number: 84
I'm looking for some 12" subs for my Silverado. Itas a single cab, so the truck box is kinda small
This is the Box;
http://www.supercrewsound.com/shop/detail/11/213.htm
I'm going to be pushing them when an old school
MTX THUNDER 2300x (Power rating RMS 300x2 2ohm's)
do you guyz think i should go with the CVR's or Infinity? or any othr suggestions for some truck subs?
I haven't heard neather of these in a truck box, but I love both of them in regular cars (civics)
Thanks in Advancd
Username: Ironslave
Offutt AFB, Nebraska U.S.A.
Post Number: 485
Me personaly i would use infinity... not a big fan of Kicker
but i guess it gears more towards if you want SQL or SPL i am an SQL person myself...
Username: Stnorris
Eldridge, IA US
Post Number: 165
actually i dont like cvrs at alll. Thats why im selling them. If you have a local shop that sells mtx audio though, i would check that out. A mtx 12" 8500 will hurt the inside of your ears in a truck. Ive heard my friends when it was in the cab behind the seat, and it was crazy. You can feel the 8500 in your chest from 10 feet away.
Username: Gangstaplayer
Gangstaville chicago
Post Number: 109
i think the kickers would do good with the 3 hundred i have heard them with 400 each and its really loud but no sq at all the 300 would do great with the kickers they are really strong subs too put like a thousand rms into them and it took them for ever to blow actually never did just got hot and broke in more
Los Angeles, CA USA
Post Number: 3981
yep they can take 1000wrms. i have 2 cvr's hooked up to 2 jl 1000/1 and they take it well. i am just using the cvr for now until i get my other subs back from treo. its being repaired.
Username: Stnorris
Eldridge, IA US
Post Number: 170
i think cvrs have nooo sq at all. But they do get loud. I had 800rms running to two of them, and it rattled my car apart. haha. but i HAVE to sell them, because the sq is just not listenable for me.
Username: Alexochoa
Tucson, Arizona USA
Post Number: 85
so i should go with infinity?
or any other suggestions?
I guess they have to be shallow mount.
I'm an SQ guy.
Username: Matt12490
Benicia, California USA
Post Number: 963
how about Type Rs
Username: Thomas_g
NM
Post Number: 772
Go with cvrs man, im satisfied with mine.
Username: Southern_bass
Paris, Tennessee U.S.
Post Number: 2272
shallow mount and type r's dont go together at all lol
Username: Alexochoa
Tucson, Arizona USA
Post Number: 86
yeah, Type R's are past the shallow part.
Thanks for your help!
