4x100RMS at 4ohm
Username: Wingback
Geneseo, IL US
I am looking for an amp that will do 100 watts RMS by 4 at 4 ohm. I was going to go with the Orion 8004, but everywhere I can find it, it is on back order? Any suggestions?
Thanks
Username: Johammbass
Cork, Cork Ireland
Post Number: 166
What's your budget? How good do you want it to sound?
Username: Rovin
Trinidad & T...
Post Number: 7960
i believe y u cant find any more is that orion came out with new models so hardly any of lasy yrs models r around still ...
http://www.directed.com/coms.asp
Username: Van_man
Boston, MA
Post Number: 354
I am looking for the same specs. This is some of the amps im considering.
INFINITY REFERENCE 7541A 4 CHANNEL CAR AMP AMPLIFIER
Soundstream VanGough VGA500.4
MBQuart RAA420
The PG xenons 200.4 th
clif designs,
Elavation audio XS125.4
Phoenix Gold Ti500.4. It pushed 4x75 RMS, closer to 85-95x4 RMS.
Ti400.2 afront stage. sound and these Ti amps Ti600.2 on my sub
usamps 4300X
75x4, bridged to "180x2"(very very very very very underrated)
how does cadence compare to JL, USAmps, Xtant, and some of the other 'higher end' amps?
Z4000
pg 800.4
Alpine MRV-F545 - Alpine 4 Ch. 500 Watt Amplifier
Hifonics NX880
Username: Wingback
Geneseo, IL US
Was looking to spend under 350 including shipping with the best sound quality, I also plan to drive a pair of MOMO 6.5 components and a pair of MOMO coax's with it if that helps as well. Right now I am waiting on caraudio to relieve their back order but as you have said with it being last years model I don't know if that will happen or not, so looking for suggestions.
Username: Killerzracing71
Fredericksburg, Virginia United states
Post Number: 799
i hope u get help cuz i want a amp like that two..i want the alpine..digital display and it will look good next to my Mb Raa-1000
Username: Rovin
Trinidad & T...
Post Number: 7965
well just like i told Killerz get a ALPINE F545 amp like i did , it cost me $340 around November & i really like it alot especially 4 its digital display
https://www.ecoustics.com/electronics/forum/car-audio/189456.html
