AMP shuts off when i raise the volume PLEASE HELP
Username: Thejoester101
Hi can anybody help me with this? I have an xplod system, the amp is 1200W max 2 channel at 200w RMS each channel, and then I have 2 xplod's 12 inch at 400w RMS each and 1400W max each (DUAL VOICE COIL). I have them connected from + to +, - to - on amp on each subwoofer, but every time I turn up the volume on my radio, it shuts off and the amp protector light comes on, can you please help me?
Username: Kevinba46
Temple, GA Usa
Post Number: 11
u are under your power not enough power and it will turn off i had a 200 watt kicker amp with a 220 rms monster cable on one 10" with 250 rms and it would turn off past 10 and then i got a 250 watt amp and a new monster cable and it hits like a beast
Username: Johammbass
Cork, Cork Ireland
Post Number: 113
Is it the Sony XM-SD22X or Sony XM-2200GTX, well same thing.
Looks like the subs are single VC, 4ohm. Looks like you have them wired in parallel to the bridged amp so it sees 2ohm mono load. Since it's not 2ohm mono stable it is shutting off, that's what it looks like.
Hope this helps you out
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 7130
^^^LOLOLOLOL
Thats not even true, underpowering ur subs will not cause them to cut off
I can almost bet that u have them wired at the wrong independence...What are the full specs on the subs and amp,,,then i can fix ur problem
Cork, Cork Ireland
Post Number: 114
Kevin, I am pretty sure that wouldn't be shutting off because "under power":-)
Thanks a lot, one of my guesses that it was wired in parellel, i will try the series set up thanks a lot guys, if i need help again ill ask. thanks
Cork, Cork Ireland
Post Number: 116
Series will not give you enough power, but at least it will operate safely
Username: Freezeman_7
Post Number: 20
yeah my subs are underpowered by about 100 watts each and they dont shut off... so im guessing your wiring is screwed
Is there anyway that i could hook them up so there are 2 channels?
Its me again, i set them up at 4ohms by doing the series connection. There is more thump but it's still shutting of at a certain volume level, it might be a higher volume level, but it is still shutting of a certain level. Any other ideas? Should i still have a left and a right input?
Post Number: 7
These are the full specs of the speakers:
XS-LD125P5
# P5 Rigid Aluminum Deposition Cone Design
# Dual 4-Layer Voice Coils
# Durable Foamed Rubber Surround with Stroke Stabilizers
# Double Damper Suspension
# Dual Stacked Magnets
# Gold-Plated Binding Posts
# Rear Voice Coil Vent with Vented Heat Sink
# Optimized for both Small Sealed and Ported Enclosures
# Mounting Depth: 5.88"
# Rec. Sealed Box Dims: 1.00 cu.ft.
# Rec. Ported Box Dims: 1.50 cu.ft.
# RMS Power Range : 125-500 Watts
# Peak Power Handling: 1400 Watts
# High Frequency Response: 2500 Hz
# Low Frequency response: 18 Hz
# Impedance: 4 Ohm
The full specs for the amp:
XM-2002GTR
2/1 Channel Amplifier
200Wx2 @ 4 ohms
500Wx1 @ 4 ohms
1200W Max Power
Post Number: 8
more specs for amp:
# 200 watts RMS x 2 at 4 ohms
# 250 watts RMS x 2 at 2 ohms
# 500 watts RMS x 1 at 4 ohms (4-ohm stable in bridged mode)
# Low-pass crossover (50-300 Hz, 12 dB/octave)
# Variable bass boost (0-10 dB at 40 Hz)
# MOSFET outputs and power supply
# Speaker-level inputs with signal sensing for automatic turn-on
# Preamp inputs and outputs
# Fuse rating: 40A x 2
# CEA-2006 compliant
# Wiring and hardware not included with amplifier
# Dimensions (W x H x D): 15-7/8" x 2-1/4" x 10-7/8"
Username: Kevinba46
Temple, GA Usa
Post Number: 12
maris thats why his cuts off and mine dont.....
Cork, Cork Ireland
Post Number: 127
Joseph,
Here is an easy solution. You should go to your nearest Best Buy, they will wire it up properly for no or very small fee, at least they will tell you and show you how it's done.
They are dual 4's so you can wire them up in series individually and in parallel to the amp, the amp will see 4 ohm mono load.
