Cheapest way
Username: Swisher
Marianna, FL
Post Number: 127
kinda sounds noobish but a buddy wants to know whats the cheapest way to beat 3 jl 13w3's runnin off a 500/1 the w3s are in a suv and the buddy has a hatchback price will be for amps and subs... hes getting a 200 amp alt soon
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 3008
2 15 comp VRs and a hifonics 1200w amp. that wont hurt you too bad. an HO would be good too. or atleast a capkiller or something.
Post Number: 3012
oh i thought you were saying the w3 guy is getting a HO. so you'll be find with the charging system. maybe a big 3 upgrade too.
Username: Jeffless600
Post Number: 132
1 15" Orion H2 for about 250 on ebay...but a 2000 watt hifonics amp to that..and you will kill a few w3's
Username: Matt12490
Benicia, California USA
Post Number: 922
^^ i think the 3 13" JLs will whoop on that H2. way more surface area and the H2 really isnt that loud. in a recent study.. the H2 sucks all around :-). you never gave us a budget tho.
Username: Swisher
Marianna, FL
Post Number: 128
you need to remember that the 3 w3 are runnin on only a single 500/1
Username: Swisher
Marianna, FL
Post Number: 129
i got some change in information.... it turns out that the jls are 13w1's .... so maybe that makes it a bit better so needs to be louder than 3 13w1s runnin off of a 500/1 in a suv
Post Number: 3016
you could beat that many ways. 2 12 cvrs ported with 800w will do the trick. are his sealed or ported? how about 2 15 crystal pro ses they are like 55 a piece and get like a 800w amp to go with them.
Username: Bulldogsm2008
Iowa City, Iowa
Post Number: 161
3 12" assassins
Username: Swisher
Marianna, FL
Post Number: 132
i got a cadence triflex 12 2 ohm today how will that fair up to them
Username: Swisher
Marianna, FL
Post Number: 142
the budget is about 250 a sub prolly lookin for 2 subs
