Like
Good 1 ohm stable amp?
Username: Hobbskc
I am looking for an amp to push TWO JL Audio 12W6's. They are Dual 6 ohms. I was going to wire them in parallel so it comes out at 1.5 ohms. Does anyone one know of a good amp that would push these? I don't want to spend alot of money.
Username: B_son
Post Number: 25
http://www.sonicelectronix.com/item_3011.html
this maybe your answer 600x1@ 1ohm
Username: Hobbskc
Would that be enough power? Continuous Power Handling is 300W per sub. Shouldn't I be looking for an amp that pushes 1000x1 @ 1 ohm
Username: B_son
Post Number: 29
contrary to popular belief the voice coils spilt the rms not doubleing it, that is a good amp and i think some other posters would agree
300x2= 600
Username: Hobbskc
Yea, but can't the subs handle up to 500 or 600 watts a piece? Or should I just get the 600 watt amp and run it at full power?
Thanks for your help in advance
Username: B_son
Post Number: 31
i'm really familar with older jl products try the sub section on this forum they may b able to help
Username: B_son
Post Number: 32
i'm not really familar with older jl products try the sub section on this forum they may b able to help
Facebook
Shop Related Deals
Directory
