Electrical System of Car
Username: Aman2005
Post Number: 50
Want to know that upgrading a car's electrical system for running a 2000 w rms amp makes any ill effect on the car's performance in any way or not?
I've a Skoda Octavia
http://skoda-auto.co.in/rtdi
Username: Aman2005
Post Number: 51
Sorry the URL is
http://skoda-auto.co.in/ritdi
Username: Ctmike
Ct.
Post Number: 620
the links didn't work for me. but find out how big the alt. is in your car first. not exactly sure the exact size you'd need, but get a ho alt. that's about 190 amps or higher and you should be set. i'd replace the battery to while you're at it. if you don't replace the alt. with one that will support all the extra requirements from you audio equip. it'll just be a matter of time until you're car dies, the amp, subs, so on.
read this
http://wickedcases.com/caraudio/charging.html
Username: Young_james
Post Number: 1523
^^^What he said :-)
