Like
Type r for $179 and x for $189 which should be bought?
Username: Aman2005
Post Number: 20
Getting
Username: Cadillacdb
Houston , TX
Post Number: 701
I would go with the X but it really depends on ur amp .. do you have the power to push the X with because if you do then go with the X... thats what i would go with
Username: Aman2005
Post Number: 22
please someone tell me the model of an amp rather alpine, because i've already spent $600 on buying a pair of type x subs. please tell me the amp which costs a lil bit less than alpine to push the x type subs
Username: Ctmike
Ct.
Post Number: 601
what's your budget for amp, was it you that said in another thread it was only $200.
Username: Aman2005
Post Number: 24
yes buddy, I said that my budget is $200. But now I am saying that I can fetch up my budget to 400
Username: Ctmike
Ct.
Post Number: 603
for $400 i'd look on ebay, maybe an orion or hifonics, something that'll put out about 2000-2500wrms @ 1ohm.
Username: Aman2005
Post Number: 25
what will be effect on quality after connecting a 4 ohm sub to 1 ohm?
Username: Ctmike
Ct.
Post Number: 604
you have one or two subs?
Username: Aman2005
Post Number: 27
I've two Type X subs. Also I want to know can a mono amp having a power of 1600 watts push these subs?
As after buying amp, I am going to place the both in my car, will that create any hearing problem for incar passengers? I mean will that produce a lot of bass and volume which one could not bear in car?
Username: Rovin
Trinidad & T...
Post Number: 7914
did u already buy/receive ur subs ?
carefully read & understand this cause u will need some current 2 power amps properly
http://www.wickedcases.com/caraudio/charging.html
Username: Aman2005
Post Number: 36
Hi Rovin,
I've bought the subs, they are on the way. I'll get them may be in between next week. That why I am curious to buy an amp before their arrival.
I want to know one thing, should I just look for an amp which is having a power of 1000 watts normal RMS with 2 ch, or should also check that how much it deliver the power when it is connected to different levels of impedence?
Username: Aman2005
Post Number: 37
Hey rovin, I have this model http://skoda-auto.co.in/ritdi.html
and found this model of amp
http://cgi.ebay.com.au/New-LV-QUART-2-Ch-1600watt-Brigdeable-Mosfet-Amplifier_W0 QQitemZ9729572192QQcategoryZ4950QQrdZ1QQcmdZViewItem
what about this/ Should be bought or not
Username: Gage
Post Number: 272
ok first o you will need ethier a 2ch amp with each ch putting out 1000rms or a a mono amp with 2000rms or 2 mono amps 1000rms and ethier way you go you will need a new alternator and battery and some nice wires
Username: Rovin
Trinidad & T...
Post Number: 7918
yes type X are good subs
but i get this feeling ur TOTALLY ignoring the current supply that ur amps 2 power them will need - when ur car is blinking & voltage starts 2 drop & u 1 day kill ur stock alt - then r u gonna call a tow truck !?
yes - u need 2 determine load/impedence depending on the subs u buy
with those X u either buy a single large 1 ohm stable amp OR 2 smaller 2ohms each stable amps .
MONO AMP are best for subs .
http://www.wickedcases.com/tutorials/index.html
Username: Aman2005
Post Number: 38
they ware
I don't want to change my car's electrical system. What In that case
Username: Rovin
Trinidad & T...
Post Number: 7920
get lower wattage subs - like the type Rs instead ......
Username: Aman2005
Post Number: 39
Rovin,
From your opinion, I think i should buy a mono amp having a power of 1000watt at 1 ohm, right?
In this case, still I've to upgrade the electrrical system? If so, how much that cost
Username: 54danny54
Betsy layne, Kentucky..GO... USA duh
Post Number: 2451
it depends on what car you have and how many extra amps of power u want.
usually a 250amp HO alt will cost in the nieghborhood of 200-300
Username: Ctmike
Ct.
Post Number: 612
get a mono amp that's 2000wrms at 1ohm for your x's.
Username: Gage
Post Number: 273
hop in o the group buy in nate lets you
Username: Aman2005
Post Number: 40
ct mike
can you please let me know that after buying a mono 2000w rms, will I've to upgrade my CAR ELEC SYS??
Username: 54danny54
Post Number: 2452
yes u will have to upgrade your electrical wuith 2000 watts...and 1000 watts
Username: Ctmike
Ct.
Post Number: 613
yes, replace the alt. before running a 2000w amp.
Username: Southern_bass
Paris, Tennessee U.S.
Post Number: 2219
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16370
an amp like that will be good for ur x's , you probably wont see the full 2000 watts , but it will be close . And if you didnt want to upgrade your electrical system , you really should have asked around or looked and found out that you have to , especially with those higher wattage subs
Username: Aman2005
Post Number: 41
Any one can help me and tell if I upgrade my alt, what will that actual cost for my Skoda Octavia and will that effect my cars other system??
Username: Aman2005
Post Number: 42
what about this
HIFONICS BXi2006D Class D Mono Amplifier Amp BXi 2006D
Username: Aman2005
Post Number: 43
I've this car
http://skoda-auto.co.in/rtdi.html
What about audio bahn?
I've found a hifonics amp here
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D9726366266
tell me abt this
Username: Pike110
Post Number: 52
Yes, it is a good idea to upgrade your elect. in the car. The stock is only enough to power the cars electrical. If it is 1000 to 2000 watts...IT IS A MUST to upgrade the alt. and batt.
Username: Pike110
Post Number: 54
I had a 250amp h.o. alt. put in my corvette for $350. The optima battery was $100. It may sound like a lot, but it is a must compared to what happens when your alt. dies. You have to get towed and then may not be able to shop around for an alt. The place you tow it too will stick you pretty good knowing your desperate to get your car running again. I know from experience.
Post Number: 2220
aman , obviously you didnt pay attention to my post
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 1212
i think you screwed yourself over and rushed into this.. you should have waited a bit before buying the subs to get more info on things.. when u start going above a system that is 1000 watts it gets expensive.. be prepared to spend 350 on an alternator that you absolutely need.. then heavy gauge wiring (can be bought for cheaper at welding supply stores).. and of course a 2000 wrms amp.. if course u can cheap out and buy one for next to nothing but it wont last and sure as hell wont push 2000 watts
Username: Aman2005
Post Number: 49
How much difference is there in type R and Type X's bass output and surround?
Post Number: 2233
type r gets loud and sounds ok
type x sound good and isnt that loud , need about 850 watts to get it going too
Username: Winterfreshpimp
Chisago, MN America
Post Number: 297
just get a power cap. lol. we all know they solve everything. naw just go with the h.o. alt and for an amp im gonna reccomend (for budget)
http://cgi.ebay.com/SoundStream-PCA2000D-Mono-D-Class-2000W-Amplifier-NEW_W0QQit emZ9729170181QQcategoryZ18797QQrdZ1QQcmdZViewItem
Username: Aman2005
Post Number: 56
What?????
Wood said that X type don't have bass/loudness as the type R ahve?
Is that true??????
Post Number: 2234
yes for the price id go with r anyday , why ? b/c the r is cheaper than the x , doesnt need as much power to get it moving , and i own a 12'' r right now and plan on getting another soon and throwing around 750 watts to each
Facebook
Shop Related Deals
Directory
