Best 15" Subs For Hifonics Amp...
Username: Mtite_dabeast
Post Number: 36
I just finished paying for a BXi2006D... Itz 2000(really 1950) watts rms @ 1ohm... I think i need 2 4ohm DVC 15" subs, but whats the best route?
My price range is less than $300 for the pair, but i can spend $500, maybe $600 on the pair.
Also, im looking for something i can go to a local audio store and just purchase or maybe order, please no special subz that i cant find on the net.
If u have a pair for sale, i can send u a money order.
Thanks
Username: Ctmike
Ct.
Post Number: 609
what's you going for sq, spl?
i think i read the aa presale for the arsenals is going on until monday, so you could get 2 15" arsenals for about $460 shipped.
http://ascendantaudio.com/index.html
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 1040
...can you spend 300 or 600?
Username: Alteraudiousa
Concord
Post Number: 787
Get some of these
http://www.audioque.com/aq/HDSeries.htm
Username: Extrmndor3
Chicago, Ill Us
Post Number: 806
hey bro im gettin a deal cuz im gonna start a team and atomic speakers are gonna sell the speakers directly to me for my team and they will affer me the 15 inch atomic apx for 390 plus shippin it will handle 25000 watts at bursts check realofexcursion if ur interested, then write back if u want me to hook you up anyone that is interested too just say something
Chicago, Ill Us
Post Number: 807
trsutme bro all the people that know spl they will know that the atomic apx will kill a pair of some ascendants and audiques
Concord
Post Number: 788
who cares about a sub thats just SPL or subs what can take 2500rms. Its a waste but good luck on your team.
Username: Mixneffect
Orangevale, Ca. USA
Post Number: 919
Take this advice;
Alsways start with your sub. Then configure how you are going to wire it. Last, you get an amp that is capable of carrying the load you have, and can produce "real" power 10-15% above the subs handling. This is called headroom.
If you get the amp first, and then try to match a sub to it, you will end up with a not so pleasing result.
Why?
Because more than likely, you will overstress the amp, or the sub will be under or over powered. In any case, it will not sound or fit right.
So, if I were you. I would put that amp aside, and look for the sub that I like. Then post here at ecoustics, to find out what amp would best suit your application. If by a slim chance, your "BXi2006D" will fit, then you lucked out.
But,
If you need adifferent amp, them I would just sell that one and get the right amp.
YOU WILL NEVER BE SATISFIED IF YOU GO THE OTHER WAY !!!!!!!!!!!!
TRUST ME.
