SPL box new!!!!!!!!!!
Username: Troy81
Tavernier, Fl Us
Post Number: 161
what kind of enclosure would you guys reccomend for a pair of memphis M3's pushed by a memphis 1100d, i have 40W X 20D X 15H to work with, i want massive SPL at about 32hz, but if i can get it to hit all kinds of notes that would be nice
im thinking about 4.4 cubes at 35 hz. what would be the dimensions of that, i dont know how to do the displacement of the subs and port and stuff
if thats no good could you help me out
Username: Troy81
Tavernier, Fl Us
Post Number: 165
bump:-(
Username: Livin_loud
Ny
Post Number: 125
Well the higher the tuning the louder it is, but you also loose SQ. If it's SPL you want though, I would go 35-37hz at most. And here's all the dimensions you would need...
Username: Troy81
Tavernier, Fl Us
Post Number: 166
is it alright if my port goes right to the top of the box? like a divider that doesnt go all the way to the back? because i was planning on making it 14.5 inches... and thank you verymuch by the way
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 1025
if you want massive SPL at 32hz dont tune above 32hz...just a little tip.
Username: Troy81
Tavernier, Fl Us
Post Number: 169
well i just want something that will get very very loud
Username: Timothy_314
Post Number: 60
some one told me 40 Hz is good SLP they said the higher tuned the more SPL
Username: Troy81
Tavernier, Fl Us
Post Number: 175
how many decibals would you guys guess that would hit, in a 96 lexus es 300
Username: B101
Queen City, NC USA
Post Number: 2835
nobody can guess what u are hittin, we dont know anything about the acoustics of your car, or how well its deaden or the resonant frequency...
so u have to burp it your self and get it measure on a accurate meter such as a Term Lab..
Username: Troy81
Tavernier, Fl Us
Post Number: 176
is that a good setup for spl?
Username: Logan__tille
Hamilton, Indiana United states
Post Number: 140
how did you do that
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 1211
if you really want spl tune around 40 45 it will get coniderably more loud than low 30's.. but you have to sacrafice one for the other .. you wont get deep bass
Username: Extrmndor3
Chicago, Ill Us
Post Number: 746
find an amp for this sub
Chicago, Ill Us
Post Number: 747
Username: Troy81
Tavernier, Fl Us
Post Number: 184
thats a cute sub, get you own damn post :P
Chicago, Ill Us
Post Number: 751
Chicago, Ill Us
Post Number: 754
Chicago, Ill Us
Post Number: 755
haha
Username: Troy81
Tavernier, Fl Us
Post Number: 187
haha
Username: Troy81
Tavernier, Fl Us
Post Number: 204
if i get a 4.5cf box tuned to 40hz, will that be good for my memphis M3's???
Username: Theweasel
Post Number: 186
eric-
what websit did you use to get those measurements?
Username: Troy81
Tavernier, Fl Us
Post Number: 205
joe
Username: Troy81
Tavernier, Fl Us
Post Number: 211
bump
Ny
Post Number: 129
http://www.carstereo.com/help/Articles.cfm?id=31
It was recommended from somebody off of here actually, forgot who though...
Username: Troy81
Tavernier, Fl Us
Post Number: 234
it was probably me because i use that shiznet, but im not sure, i would like someone to answer my question because ive bumped this damn thing 50 times
Ny
Post Number: 131
Um, It'll be louder than anything tuned below it, but sound worse. You'll also loose your low end, and I don't think you want that. The audible difference I don't know though. I'd say go 36hz at the most, because it'll still be loud and give you decent lows.
Ny
Post Number: 132
didnt bump
Username: Troy81
Tavernier, Fl Us
Post Number: 239
so will the low end jus comeppletely stop hitting or what? i dont understand that about that, or will it just not get the boost from the box
Ny
Post Number: 134
Personally, I don't know haha. My guess would be they'll loose a few dB's
