Line out question
Username: 442boy
Post Number: 23
ok i know on the back of the HU that thier are the right and left rca out puts .....but if i am running 2 amps where should they go first the amp for the midbass and tweeters or the subs....
and also what is sq and spl?
Username: Illuminator
Post Number: 3029
SQ=sound quality(quality of sound)
SPL=sound pressure level (loudness of sound)
If you have two amps but only one set of pre-outs, you might want to get an RCA y-splitter. I'm not sure what you mean by:
Username: 442boy
Post Number: 24
ok umm to broad
umm both of the amps have a line in and a line out both left and right so would it be better to run the signal line into the amp that is going to run the mid bass/tweeters ...or run it through the one for the subs....or does it even matter
Username: Tjmutlow
Post Number: 2092
what headunit are you talking about
Post Number: 3034
So essentially, you're going to daisy chain the two, right? It won't matter, the amp will add negligible sound characteristics to the line out on it.
Username: Kevinba46
Temple, GA Usa
Post Number: 10
i have 1 audiopipe tsv 10" and 1 12" of the same model and they are both dual voice coil 4 ohm subs what kind of amp should i get and how do i wire it?
Username: 442boy
Post Number: 25
ok so would it be better to just have a line slitter?.....and ty the hu is an sony xplod
