2 15 Arcenals VS 1 13W7
Username: Bassiloveu
Post Number: 24
Ok i have decided to go with 2 15 Arcenals with a 1200D and i was wondering how that would match up against my friends 13W7 with a 1000/1 he says the 13 will be louder i just wanted to get your guy's oppinion so what do ya think???
Username: Redliner
Wilmington, Ma
Post Number: 1909
well are you matching each arsenal with a 1200 d cause arent they rated at 1000 per.
also what kind of cars are they going in do you have the correct charging system
Username: Seth_walker
U.S.A.
Post Number: 126
the arsenals are 750w rms, 600w rec., not 1000.
U.S.A.
Post Number: 127
As for who'd win it's tuf to say. I haven't heard the arsenals but the W7 does get pretty loud. As long as you have a good install then i'd say you have a good chance.
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 2976
are you guys kidding? you would have to have about the worst ascendant audio install ever to not be louder. over twice the surface area and more power.... no brainer.... your setup should stomp his.
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 2163
if you were comparing 1 15'' Arsenal to 1 13W7, then that might be close. but 2 Arsenals should do the trick.
i had a 13W7 ported and now have a Treo SSI 15 sealed. the Treo is just as loud as the W7 with better SQ imo.
