To alpine or not to alpine......>?
Username: Mahoney
Norris CityUSA
Post Number: 12
I am looking at 3 apline type s for my regular cab sonoma and i wanted to know if there is anything better for the money with around the same depth of the type s. I found the type s for like 80 bucks...so if you know any sub i can get for the same money that is better help me out...thanz
Username: Basshead86
Google is your Friend, FL
Post Number: 3409
you could try the Ascendant Audio Assassin
www.ascendantaudio.com
they are about to go off of their special sale...
Username: Southern_bass
Paris, Tennessee U.S.
Post Number: 2190
personally i would try the type s .... idk what u can do for amp though ... unless u have room for 3 amps and in a single cab truck u wont
Post Number: 2191
jl 1000/1 would be perfect for that ... dont figure u can afford it though
Username: Mahoney
Norris CityUSA
Post Number: 13
Not right now i have a 12 inch rockford fosgate HX2 hooked to a 1000M profile california series amp in my reg cab truck. i have enough room for 3 amps if they are small enough. I have heard of Ascendant Audio...i heard they are pretty good ill check into them.
Username: Freezeman_7
Post Number: 7
you should defintly hit up dB drive www.dbdrive.net they have some pretty affordalbe stuff that sounds awsome
Username: Mahoney
Norris CityUSA
Post Number: 15
are both there amps and subs good....and do i have to call to get the prices for their products
Username: Fandim
Reno, Nevada United State...
Post Number: 1003
You could get a Phoenix Gold Xenon 1200.1 to power three type S and it'd sound great.. and a lot cheaper than a 500/1, too.
Username: Mahoney
Norris CityUSA
Post Number: 17
Where is the cheapest place i can find a Phoenix Gold Xenon amp
Username: Mahoney
Norris CityUSA
Post Number: 21
where is the cheapest place that sells Phoenix Gold Xenon amps
