Need to power my type-r's
Username: That_one_guy
Post Number: 15
So i just ordered 2 12" alpine type-r's and realized my old amp will not power them. So I'm turning to you guys to find out what the best way to power them is.
http://sonicelectronix.com/item_4281.html
Username: Dustin3
Tigard, Or U.S.
Post Number: 1138
i would get:
http://cgi.ebay.com/Kicker-KX1200-1-Mono-Amplifier-w-Remote-Bass-Controller_W0QQ itemZ9726359660QQcategoryZ79829QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
or you can find it elsewhere
Username: Dustin3
Tigard, Or U.S.
Post Number: 1140
http://cgi.ebay.com/ebaymotors/Orion-amplifier-1200d-like-new-with-box_W0QQcmdZV iewItemQQcategoryZ38638QQitemZ8067086935QQrdZ1QQsspagenameZWDVW
Post Number: 16
How would I wire two subs into a mono amp. sorry i don't know, i'm kind of new at this.
Username: Dustin3
Tigard, Or U.S.
Post Number: 1142
since you want to get 1200 watts to both of those subs, dual voice coil 4 ohm subs can either wire to 1 or 4 ohms: so for the kx1200.1 you want to wire to 1 ohm because it puts out 1200 @ that: wire it like this:
Username: Goatin
Ohio U.S.A
Post Number: 1086
If your subs are 4 ohm.^^^
Username: Dustin3
Tigard, Or U.S.
Post Number: 1144
they are
Post Number: 17
thanks guys (especially bassman) you've really helped me out alot. If you have anything else to add please feel free to do so
Username: Rovin
Trinidad & T...
Post Number: 7891
well ican offer u a pointer - port them & tune around 33hz , u will LOVE IT !
u can get some ideas from my install of the same subs which i own
https://www.ecoustics.com/electronics/forum/car-audio/189456.html
Username: Dustin3
Tigard, Or U.S.
Post Number: 1147
^^ lol. i knew u would be comin around soon rovin
