Alpine MRV F545 any 1 had 1 or want to sell 1
Username: Killerzracing71
Fredericksburg, Virginia United states
Post Number: 758
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2460
i want to get 1 of these...to run 2 8" tangbangs and a set of componets.....for a crucial frontstage...to comploment my 2 (soon to purchase) RLP 15....now i have 2 MB Quart PWE-354
so any1 have 1 or ever used 1 or would sell me 1
Post Number: 766
bump this postthiszzle 2 da TOP
Post Number: 768
this thing aint bump
Username: Rovin
Trinidad & T...
Post Number: 7851
guess what killer !?
apart from U & I both owning that same MB amp - i ALSO own that very alpine 545 amp !!!!!!!
pushing my (4) Inf Ref 6.5" comps with it
its a sweet amp & i have 0 complaints about it , 1 comment , it does run warm but its class A/B so thats expected ...gr8 amp........
Post Number: 769
LOL...rovin......do u have AIM....mines Killerzracing...or have i talked to u...on AIM...i cant remeber...
Anyway Rovin where did u get urs.....and how much...
i want one to power 4 or 5.25" componets and 2 8 subwoofers...either Tangbang, RLI, AA, RE8 or something else....i want to bridge the last 2 channels to getr 300watts... doesnt it have a digital display.....do u have problems with ur alt running those 2 amps....cuz i have a stock alt...i realy want that...amp....i want something that will compliment my MB amp...
Username: Rovin
Trinidad & T...
Post Number: 7861
yeh - it does have a degital display which is sweet cause it helps u set everything accurate
Specs:
Bass Engine
* Crossover Network : 30Hz-200Hz HP / LP (12dB/oct)
* Tuned Bass EQ (Variable) : 45Hz +16dB (Ch-3/4)
General-Amplifiers
* Frequency Reponse : 10Hz-50kHz (+0,-1dB)
* Heat Sink (WxHxD)in : 16-1/2" x 2-5/16" x 8-11/16"
* Heat Sink (WxHxD)mm : 420mm x 60mm x 220mm
* Input Impedance : 10k ohm
* Input Sensitivity (for rated power) : 0.2 V to 4.0V
* Power Requirements : 14.4V DC (11V to 16V)
* Signal to Noise (S/N) : 96dBA (referenced to rated power)
* Slew Factor : greater than 5
* Speaker Impedance : 4 or 2 ohms(stereo), 4 ohms(bridged)
* Weight : 4.0kg.
RMS Power (at 12V,20Hz-200Hz)
* Bridged 4 ohms : 300W x 1 (Ch-3/4)
* Per channel into 2 ohms : 150W x 2 (Ch-3/4)
* Per channel into 4 ohms : 100W x 4
RMS Power (at 14.4V,20Hz-200Hz)
* Bridged 4 ohms : 125W x 1 (Ch-3/4), 500W x 1 (Ch-3/4)
* Per channel into 2 ohms : 250W x 2 (Ch-3/4)
4 ur com ps make sure & get a nice strong pair around 100wrms cause this amp does put out rated power .
well i recently sold me MB amp on 30th march 2 Nester - when i had it & with my alpine it hardly ever blinked off my 80A alternator.
mostly @ night im on - my aim is RovinFromTT
i bought mine around nov from discounts jungle - @ the time it was $340 which was a good price
what u can do since ur car is RWD is go 2 a junkyard & pick up the highest amperage alt u can find , then make a bracket & have that 'new' alt charge a a separate dedicated batt 4 ur audio - or buy into Nate's may alt special deal.
Post Number: 770
im confused.....can u just bridge the last 2 and make 500watts and leave 1/2 seperated for a 3 channel amp... and at whut ohm is the 500watts....4 ohms right...all i see is if 3/4 are bridged no 1/2....think it was just a typo..i want one so bad
