Dash lights not working
Username: Phatty34
i need help!!! i have a 1999 isuzu rodeo and the factory wiring end has been cut off i then wired it directly to the cd player as a result. i have lost dash lights since then. the fuses are all fine and no wires are touching each other. what can i do
Username: Lexuscoop
Pheonix, Arizona USA
Post Number: 193
check the dash its self, maybe when you were installing you turned a nob that dimmed the dash lights
