Silver Member Username: Scott_debakerPittsburgh, P.A. U.S.A. Post Number: 349 Registered: Feb-06 | ![]() ![]() ![]() ![]() ![]() |
Bronze Member Username: Kaos13Post Number: 71 Registered: Oct-04 | excellent setup. looks d@mn good im not a fan of fur but it still looks good |
Silver Member Username: Scott_debakerPittsburgh, P.A. U.S.A. Post Number: 350 Registered: Feb-06 | lol sounds go0d iam goni 2 turn the gain even more an the hu skips 2 lol an the car was in the garage an upstairs candles fall of dresser lol |
Bronze Member Username: 442boyPost Number: 12 Registered: May-06 | looks awsome ....could look better (try hiding the wires) |
Silver Member Username: Scott_debakerPittsburgh, P.A. U.S.A. Post Number: 351 Registered: Feb-06 | 2 thick an the seats right there an cant get them behind it theres no space an i think it looks ko0l with them lol |
Gold Member Username: RovinTrinidad & T... Post Number: 7804 Registered: Jul-05 | Not bad @ all = here's what i would do 4 my personal taste : leave out end caps on that amp - i have same amp & i really dont like those ends @ all not feeling that white fur thing , maybe black if u like fur or textured leatherette material i would also (if possible) mount that amp in a more discrete location cause where u have it 'advertising' there it will def attract thieves Do u have a HO alt or more batteries ? - cause that amp is gonna draw alot of current , which is y i havent hooked up mine as yet & i hope ur mids/highs can keep up with that amt of bass . im NOT criticizing ur install though - just my .02 cents .... ![]() |
Silver Member Username: Scott_debakerPittsburgh, P.A. U.S.A. Post Number: 352 Registered: Feb-06 | no h/o alt. volts dont drop below 13 volts an iam gettin windows tintd 5% an end caps r ok dont really liek them but matches lol but the subs pound an the speakers keep up but i turn my hu up all da way an speakers sound bad so when the car is on the road iam goin 2 tun it @ vol 40 where it sounds go0d an then ill turn gain up a lil more an its runnin @ 2ohms 1700W |
Silver Member Username: Scott_debakerPittsburgh, P.A. U.S.A. Post Number: 353 Registered: Feb-06 | monday i might even rebuild this 1 box i got an make it the same as that box but go with a 2inch port tuned @ 24hz an c how that sounds |
Silver Member Username: Matt12490Benicia, California USA Post Number: 831 Registered: May-05 | should buy an alarm |
Silver Member Username: Matt12490Benicia, California USA Post Number: 832 Registered: May-05 | even if you do have 5% that wont help that much.. k look, they will hear your car is helllllla loud and they will follow you. then they can put they eyes up to the glass and see thru it but only if they put their head right against the glass (i have 5%) then they will jack you which is allll bad. so you should get an alarm and so should i |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 6966 Registered: Jul-05 | what happend to ur 15????? |
Silver Member Username: Scott_debakerPittsburgh, P.A. U.S.A. Post Number: 354 Registered: Feb-06 | never got the 15 sx yet an hey guys remember insurance full coverage its my moms car lmfao lol i dunno what i should do box now pounds an the whole hatch on (dope boi magic) the flexing it gos side 2 side lol an whole back window pushes out its sweet lol i dunno if i should make the same box but a 2inch port an tune it low since i love low bass or should i tune it @ 40hz with a 3inch port? |
