SQL
Username: Lexuscoop
with my 2 jl 10w6v2's is there a way to make a custom fiberglass box that will give them this or are they just strate up SQ subs?
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 2852
they are SQ subs but i have seen plenty of times where they get quite loud. for that, the best way to go is MDF ported though.
Username: Lexuscoop
Post Number: 12
damn... well i don't even know if i can use my JL's in my incomming car... so this might suck...
Username: Ucfsaxman
Oviedo/orlando, Fl
Post Number: 762
whats your new car gonna be
Username: Lexuscoop
Post Number: 24
its going to be a lancer evo... not sure if its going to be the RS or the 9
Username: Ucfsaxman
Oviedo/orlando, Fl
Post Number: 765
oh wow sweet i love the evo's i have a galant now and i have a history w/ mitsubishis. you could easily fit those 2 10w6v2 in there in just might be a a little heavy between the 2 of them and a box for them. but its not like the evo doesn't have enough power :-)
Username: Lexuscoop
Post Number: 35
yea, since you got the history, would they void the warente(sp?0 if i add 800watts?
Username: James1115
Ct
Post Number: 5804
no they shouldnt at all. How would they ever know? all you woul have to do is take your box out if you go to the dealership for anything.
Username: Lexuscoop
Post Number: 36
yea... true... but i don't want to risk it you know? 10 year 100,000 miles limited warentee... do they have the spects on the mits website?
