Silver Member Username: ShawnomakSask Canada Post Number: 249 Registered: May-05 | I was told that if I was on a budget to get an Audiobahn A8000T amp for my Infinity 1230's. I was also told that Audiobahn is a horrible choice, but nobody gave me reasons why. I was wondering what was wrong with them? Bad sound quality? Break easily? Anybody know reasons why I shouldn't get this amplifier? |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 3342 Registered: Aug-05 | they are cheap amps. and they are overrated.![]() |
Silver Member Username: ShawnomakSask Canada Post Number: 251 Registered: May-05 | My subs are 300W rms a piece and it puts out 800 @ 2 ohms, so it will match them ok, right? And.. Cheap as in not much money or cheap as in not made very good? |
Silver Member Username: ShawnomakSask Canada Post Number: 252 Registered: May-05 | http://cgi.ebay.ca/Audiobahn-A8000T-Intake-Mono-Block-1600W-Chrome-Amp-NEW_W0QQi temZ9723546691QQcategoryZ64571QQssPageNameZWDVWQQrdZ1QQcmdZViewItem ^Thats the one I was looking at. All the specs are there. |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 3344 Registered: Aug-05 | that amp will make roughly 600wRMS at its lowest ohm load. it is a Class A/B amp....and has 2 30A fuses...so maybe a little less than 600. ![]() |
