Need some help
Username: Steve_collins
Post Number: 81
ok so im buying subs cas its my birthday. i would like for now juts pure spl and i was thinking of a pioneer premier 1000rms or 2 cvr 12 and i really dont know what to get. this is just a starter system so about 150 and spl thanks a lot.
Username: Lexuscoop
Post Number: 48
2 CVRs would be very nice
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 2904
maybe even 3 12 crystal pro ses? they are 50 a piece. and 3 12s should be louder than 2 12s of CVRs. and you even get a better sounding sub. http://www.realmofexcursion.com/store/product_info.php?cPath=21_61&products_id=1 44
Post Number: 83
ok sweet would 2 pioneer premier out do 2 cvr.
Username: Lexuscoop
Post Number: 50
^^^ agrred 3 crystals would be louder 3db louder right? and they'd be getting just over the RMS handling
Post Number: 86
sorry i dont have space for 3 12. so thats why i was thinkin 1 pioneer premier because i was told it will produce more bass than 2 cvr but if there is something better i would like that ahah thanks a lot
Username: Lexuscoop
Post Number: 52
lok at the AA line they have good stuff
Post Number: 2905
well, by rule, if the pro ses are as loud as CVrs 3 would be 1.5db louder than 2. but if hes going to put more power also, then the decible level would increase more. if he gets 3 4 ohm subs. wires them p[arallel to 1.33 ohms hed be good with a 1200-1500w amp at 1 ohm. make sure you upgrade your electrical system though.
Username: Johammbass
Cork, Cork Ireland
Post Number: 30
Just install a jet engine and turn on the afterburners, that's it:-)
Post Number: 87
i have a mb quart raa1000 amp mono
Cork, Cork Ireland
Post Number: 31
Man, I got no clue about SPL:-(
Username: Lexuscoop
Post Number: 54
well even then thats only 118dB... + or - a few dB's lol
Post Number: 88
how about 1 rockford t1 would that be the best.
Post Number: 2908
2 12 CVrs would be louder than 1 12 pioneer.
Post Number: 89
ok well these are what i want so help me out.
1 pioneer premier
1 rockford t1
2 kicker cvr
all i want is bass and yea so which is the best
thanks
Post Number: 2911
t1 is louder than CVR. but 2 CVR is louder than 1 T1. dont know much about pioneer subs but almost surly the 2 12 CVRs is the loudest setup you have listed there.
Username: Drivingreckless
Near tampa, Florida United state...
Post Number: 308
IM GUESSING THE T1 WILL GET THE LOUDEST BECAUSE THEY ARE PURELY FOR SPL
Username: John_wash
Nashville, Tennessee
Post Number: 279
get the 2 cvr's Stephen
Post Number: 2916
T1 is actually an okay driver. its the T2 thats purly spl.
Username: Sw9152
Michigan
Post Number: 640
what about a 15" L7, you can find an '05 on ebay new for about $175. would get louder than any mentioned so far.
Post Number: 91
so a l7 is a better deal than 2 cvr
Post Number: 2925
for spl, yes.
Post Number: 310
OH I SEE..SO WOULD U SAY THE T1 IS SQL
Post Number: 92
would a 12 l7 still beat 2 kicker cvr
Username: Sw9152
Michigan
Post Number: 648
with the same watts probably
Username: Sw9152
Michigan
Post Number: 649
probably, with the same watts
Username: Sw9152
Michigan
Post Number: 650
damnit...
