Only the best...
Username: Bakerj72
Regina, Saskatchewan Canada
Post Number: 141
Alright, I doubt it's a repost but I want to see some good arguments and good equipment.
TOP 5 250-500 wrms SPL driver
TOP 5 250-500 wrms SQ driver
TOP 5 250-500 wrms HQ amplifier
TOP 5 250-500 wrms Bang for your buck amp
TOP 5 500-1000 wrms SPL driver
TOP 5 500-1000 wrms SQ driver
TOP 5 500-1000 wrms HQ amplifier
TOP 5 500-1000 wrms Bang for your buck amp
TOP 5 1000+ wrms SPL driver
TOP 5 1000+ wrms SQ driver
TOP 5 1000+ wrms HQ amplifier
TOP 5 1000+ wrms Bang for your buck amp
TOP 5 Deep Cycle Batteries
I'm not gonna get into HU's
Username: Ogduncan
Post Number: 45
i dont think any sub with over 1000 watts would be considered SQ.
Username: Bakerj72
Post Number: 145
RE
ID MAX
ECLIPSE TI
w7
TREO
they can all take 1000wats and sound amazing
Username: Udontknowme
is it true that with amps that have listed on the specs... for instance 1000watts continous
that is not infact true and that the REAL watts are not listed in the specs???????
Username: Ctmike
Ct.
Post Number: 439
"is it true that with amps that have listed on the specs... for instance 1000watts continous
that is not infact true and that the REAL watts are not listed in the specs???????"
what you mean by that^^?
depending on the brand the wrms may actually be lower, some higher, than what you'll actually see. some are underrated, others are overrated. you also got to see what there rated by, like rated at 14.4v is most common i think.
is that what you asking?
Username: Ctmike
Ct.
Post Number: 440
give you example-i bought a kicker 1200.1 mono amp awhile ago. specs say 1200wrms@1ohm, but when i opened the box the birth sheet said something like 1415wrms@1ohm. so i made out and got an extra 200+
Post Number: 9
what is wrms???? i was told that even though its listed at 1000 continous. some amps do hit 1000 and some dont
Username: Ctmike
Ct.
Post Number: 442
amount of power an amp produces continually at a given load. this is what you want to look for, never go off of peak power on specs.
"i was told that even though its listed at 1000 continous. some amps do hit 1000 and some dont"
that's what i meant in my last 2 posts. depending on quality of the amp/brand you might get the full 1000 (actually rated), might get less (overrated), or get more (underrated).
Username: Thomas_g
NM
Post Number: 380
yup yup just like the 268 lanzar amp that i got its overrated but still puts out a little over 900 rms bridged great power for $150. I rate this amp 1 of the best bang for the buck amps with rms between 500 and 1000!
Post Number: 10
so what is the premier PRS-D3000SPL rated at
Username: Ctmike
Ct.
Post Number: 443
blah blah blah-also, this thread was started by justin for another question/reason. next time if you got a question, start a new thread. not trying to sound like a d!ck, but not really cool to jack someone's thread. start this back up in another thread if you want to keep it goin.
Username: Thomas_g
NM
Post Number: 381
yup yup agree w/ctmike.
Post Number: 15
my bad
Username: Thomas_g
NM
Post Number: 385
OMG jimmy is blah blah blah!JK. Bring humor to this mutha cuz its dead.
Username: Redliner
Wilmington, Ma
Post Number: 1789
for 500-1000 sq driver i say w6v2, idmax right off the bat
for 1000+ i say dd 9100 for sq
and for 1000+ spl dd 9900z
Username: Zepcoe
TN Us
Post Number: 270
Is orion a (actual rated) amp? 2500d amp.
If i was to hook 2 12 ssi's up to a 2500d orion amp with 1500wrms continious to each sub would it stay around 1500?
