Kenwood KDC-MP832U vs. KDC-X890 or excelon VS. MP
Username: Bradgman
GAlVeStoN, Tx Usa
Post Number: 161
What is the difference between the Excelon kenwoods and the MP ones? They are the same price and look the same with the same options. Heres the specs
USB/AAC/WMA/MP3/CD Receiver with External Media Control
Auto-Slide Detachable Faceplate
Rotary Encoder & Jog Control Knob for Easy Operation
64 Color Fine Dot FL Display
Display Off Mode
Maximum Output Power: 50W x 4 (MOSFET Power IC)
USB Interface (Type A, 1.0m Pigtail)
ACDrive (Advanced Codec Drive)
AAC/WMA/MP3 Playback
Optional Bluetooth Hands-Free Unit Ready (KCA-BT100)
G-Analyzer (Graphic Motion Analyzer)
System Q/System E's+
Installer/Backup Memory of Audio Setup
SIRIUS Satellite Radio Ready
HD Radio Ready
External Media Control -- iPod Ready
TEL Mute
Dual Zone Source & Volume Control
AUX Input
3 Preouts with 4V Pre-output Level
Display Customize Function
Display Off Mode
System Q-ex/System E's+
HD Radio Ready
TEL Mute
AUX Input
Gold Plated 3 Preouts with 5V Preoutput Level
Steering Remote Input
Username: Mrbass
Long beach, California United state
Post Number: 35
there is no difference , they just have two different version and names
Username: 7ate9
That is not entirely correct. I've been contemplating the same thing, since (nearly) every excelon model has a correlating "base" model. At the very least, the preamp outputs on the MP series are crippled (4v versus 5v in the above case, bigger differences for other models). What I don't know is if the components are actually different, or if they just have different internal settings. Hope you're still looking at this thread.
