Box question(all the box builders need an advise)
Username: Extrmndor3
Chicago, Ill Us
Post Number: 620
wats the most common box tunnings in a suv, car and truck for spl??
and wats the common box tunning in a suv, car and truck for sq?? no spl.
and finally wats the tuning for each type of vehicle for sql??
thanks alot ;)
Username: Scott_debaker
Pittsburgh, P.A. U.S.A.
Post Number: 271
for spl tune it high like 38hz--40hz or u wanna go spl for 1 note get the cars top fre. an sq i would say tune it low sounds best low i think an i prefer an dont no about the cars sql
Chicago, Ill Us
Post Number: 621
yeah i know that but i want to know wats the common resonance freq of each type of vehicle for suv i think is around 40-45 hz but i have no idea for truck or cars,
and i want to know the best tunning freq for spl, and sq for each type of vehicles
Username: Matt12490
Benicia, California USA
Post Number: 783
i would go like this
28-32hz - SQ
33-37hz - SQL
38-45hz - SPL
Username: Rovin
Trinidad & T...
Post Number: 7700
thats pretty good ^^^ ..
Username: Emdawg12345
Post Number: 31
http://www.rotteneggs.com/?refid=182315 read this it shows a bunch of things ull probobly find use full
Post Number: 32
Username: Sw9152
Michigan
Post Number: 554
^^^yeah i used to go on that site when i was interested in making homemade bombs.
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 2875
lilrob...you have an explorer, right?
if so, go w/ sub up port back. line the back of the box up w/ the last 2 latches on the floor.
your vehicle is gonna have a peak at 42-45hz. Since you are using an SX, tune to ~39hz and go from there. (if you can get on a mic, try to do some testing w/ a sealed box to find your true peak)
Chicago, Ill Us
Post Number: 622
thanks alot marshal but i already did the box u remember that u told me sub up and port back i did it the volume was 9.8 cub ft and the tuning was around 43 hz the thing is that i did interchangeble ports so i want to have diferent configurations and im buldin some friends box but he have a car so i dont know how to tune it in a car , marshal im doing around 145 db at the dash in the termal lab wit the box and the precicion power dcx1500.1 thanks marshall
Post Number: 2880
what kinda of car does you friend have?
Chicago, Ill Us
Post Number: 623
he have a dodge neon 97
Chicago, Ill Us
Post Number: 624
he wanted the interchangable ports but in a car i dont know how to tune it is the same in a car and suv??
Post Number: 2883
if i remember right neons like to peak around 49-52hz. (only bout 70% sure on that one)
i would try tuning to 35-36hz for daily since its a truck-car.
Post Number: 2884
btw...to get a box to peak at 49-50hz, you will want to tune alil lower than that freq.
usually 3-8hz depending on sub and box size.
Post Number: 2885
oh...and do you have any pics of the box you built for the SX18?
i'd like to see how it turned out.
Chicago, Ill Us
Post Number: 626
dont you remember that i posted wit the brochure of the reaudio subs but i will show them to you hold on
Chicago, Ill Us
Post Number: 627
Chicago, Ill Us
Post Number: 628
Post Number: 2888
lol....nope i dont remember.
but i have slept since then :-)
Chicago, Ill Us
Post Number: 629
Chicago, Ill Us
Post Number: 630
