Its powering 2 Audiobahn 12"s at 400 rms each (their not the greatest)
Well, my problem is that a few weeks ago I was bumpin music a little bit louder than I usually do, and the amp just turned off and the protection light turned on on the amp as well as the bass control knob.
Now, whenever i turn the bass up to even just a quarter way up, it turns off and the protection light goes on again.
Some said I needed a new battery. I just got a new battery the other day and the problem is still there. Some also said that the ground wire must be touching metal somewhere. Well me and a few friends checked it pretty thoroughly and we couldnt find any places where its touching any metal.
If you could give me some advice before I go to a local audio store and get ripped off and probably buy things I really dont need, it would be greatly appreciated!!
What is the VC configuration on your subs? DVC? 2 ohm? 4 ohm? How are they wired? Series? Parallel? Series/Paralell? Is the amp really hot to the touch? It could be a number of things, so let us know this to begin with.
