Hooking up 3 subs to one amp
Username: Eseesai
Post Number: 68
im trying to c if i can hook up 3subs to one amp the amp is a hifonics and the subs are 2ma audios svc 4ohms and the other one is a kicker cvr10 svc 4ohms is it possible
Username: Wolfman1966
WEST MONROE , LOUISIANA USA
Post Number: 92
it is possible if either the amp is 1 ohm stable, or if you hook the subs up in series(as opposed to parallel). However, if you hook them up in a series, you don't get as much power to each sub. Also, it is not a very good idea to mix two different kinds of subs.
