Couple of problems wiht my HU
Username: Goose5714
Post Number: 452
I installed it and that went fine...but the antenna chord doesn't fit into the space for it on the back of the HU. I have a 1998 camry and its a pioneer deh670mp unit...maybe i need an adapter?? Also it wont take cds...i physically can't get them into the drive...i'm guessing its broke right?thx
Username: Illuminator
Post Number: 2962
They do sell adaptors if the stock antenna doesn't fit, yes.
Is the unit used or new? If it's still under warranty, it should be taken back.
If not, the plastic slides that prevent a CD from entering the unit when a CD is already in there might be in the way.
