Do i HAVE TO HAVA a sub with iridium 6.2?
Username: Jinster
Post Number: 35
im not a big sub guy.. and i hate rap. so do i have to have a sub with iridium 6.2s to appreciate my music 100%? thx.
Username: Goatin
U.S.A
Post Number: 955
What are you asking?
Username: Sw9152
Michigan
Post Number: 525
what is an iridium 6.2? you prolly dont need one.
Username: Basshead86
Ocala, FL
Post Number: 3163
I already answered it in another section.:-)
Username: Sw9152
Michigan
Post Number: 526
you need speakers but not specifically the iridiums.
Ocala, FL
Post Number: 3169
he is asking if he needs a sub after he installs his DLS Iridium 6.5" Component Speakers.
NO....you do not NEED a sub....but your Iridiums will not produce sub-bass freq. as loud as a sub.
Username: Rovin
Trinidad & T...
Post Number: 7663
maybe get a pair of 8" JL subs SEALED just 2 have the full spectrum of music & NOT just mids/highs sounding like a factory big radio -lol....
Ocala, FL
Post Number: 3174
thank you!:-O
Username: Killerzracing71
Fredericksburg, Virginia United states
Post Number: 688
yeah an he did answer u question in another thread....guess u aint like his answer....anyway....all songs do have bass....so a subwoofer would help....so if u dont want a sub to help ur expericance of music in your car....just put in a set of headphones and call it a day....have u ever seen a hi fi..home theater setup without a subwoofer.....nope....cuz they fill in deep tones....
Username: Mikechec9
Post Number: 2381
The 6.2 will do well down to 40Hz AT LOW VOLUME.
At higher volume, the set does well to 55-60Hz. Don't confuse mid-bass drivers with subs.
Even the larger ones. If you're not fond of larger subs per se, E.D. has a good 6.5" sub on sale for 50.00. Two of them would do well. Especially if hidden. I'm seriously leaning toward them to go in my center console.
Regardless, there is no substitute for a good sub.
Username: Jinster
Post Number: 36
sorry about the repost in the other section guys but i thought i had posted this in amp section fist and when i couldn't find it i thought the admin had removed it so i came here to repost.... anyways, should i get dual 2 or dual 4 coil config for ed-700 if i'm getting a pair of them? thx.
Username: Mikechec9
Post Number: 2382
Depends on the amp
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 1155
remember to sound deaden the hell out of your doors to get the most outa the speakers..
do you have an amp already for the subs?
