What
Username: Shortysetnies
Rock Vegas, NC US
Post Number: 88
I was entering some ifo in on 2 15" AA arsenal subs and the "box builder" gave me this:
http://www.accelerator-pedal.com/ported-box.asp?Ew=44.5&Eh=36&Dia=9&Xmax=20.5&Vd =.16&NumW=2&Vb=5.5&Fb=28&Qts=&Vas=&Fs=&CE=0
http://i1.tinypic.com/x3wtnq.jpg This is it with the sub in it. look at that too.
I drew it exactly the same lengths they gave me at the and I told it all the correct info. Why is it only wide enough to fit one sub? It is tall enough to do them on top of each other but I don't want to do that.
Rock Vegas, NC US
Post Number: 89
Hope that question didn't confuse anyone. ^^
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 2775
for starters you need about 7-8 cuft NET
Post Number: 2776
8cuft will fit it just perfect... should anyway.
Username: Sw9152
Michigan
Post Number: 512
http://www.accelerator-pedal.com/ported-box.asp?Ew=44.5&Eh=24&Dia=9&Xmax=20.5&Vd =.16&NumW=2&Vb=8.0&Fb=30&Qts=&Vas=&Fs=&CE=0
oh and where did you get autocad? how much did it cost?
Rock Vegas, NC US
Post Number: 92
I use autoCAD at work so it is FREE!! Will run the normal person 3k or so.
Rock Vegas, NC US
Post Number: 93
thanks for that page SW
Username: Suleman36
Maryland U.S.A.
Post Number: 3646
I whould recommend you go sealed with the Arsenal 15. It will sound better overall and get loud. It seems to gear more towards sealed like most 15's but not all.
Username: Sw9152
Michigan
Post Number: 521
i use autocad at school, sweet program. almost thinking about trying to download off the comp to a thumb drive. not sure if that would work, but would be cool if it did.
Rock Vegas, NC US
Post Number: 94
Yeah I'm in the engineering department at a large pharmaceutical plant and I work on AutoCAD and Inventor. I love that job. Be careful. Not sure of the exact punishment but I have heard if you are caught with it they can fine you the amount of the program for every day you've had it illegaly. So... if youve had it five weeks 5x7=35 35x3,000=$105,000 in fines. Be carful.
