Some good cd players?
Username: Dadydolas
Post Number: 54
i know its the wrong section but no one goes in the other one
Username: Ctmike
Ct.
Post Number: 384
pioneer premier and alpine are some of the best out imo. i did hear that the new alpine's with the touch glide feature are difficult to use and that alpine has had problems with these ones' so far.
Username: Dadydolas
Post Number: 55
how many volts for the amp pre outs?
Username: Ctmike
Ct.
Post Number: 385
all brands are different, look at the specs for each one. i think eclipse have some of the highest though, i think they range from 5-8volt.
Username: Dadydolas
Post Number: 56
is more volts a better signal
Username: Ctmike
Ct.
Post Number: 387
Preamp Output Voltage
The output voltage of the receiver's preamp outputs. Higher preamp output voltage can mean cleaner sound (better noise resistance) and higher output from your amp.
Username: James_g
TN
Post Number: 465
The Glide Touch feature on the Alpine HUs isn't really difficult to use at all. It takes a day or two to get accustomed to using it, but it's not difficult.
