This sounds good to me?!?!?!?!?!!!
Username: Extremesound1
Coventry, RI United states
Post Number: 137
i already have a really nice pioneer dehp7700mp cd player.im working from the top to the bottom. so me next step are this nice component setUpload
buying it off ebay right here
http://cgi.ebay.com/SOUNDSTREAM-TRC-6N-6-1-2-TARANTULA-COMPONENT-SPEAKERS_W0QQitemZ9717793348QQcategoryZ32819QQssPageNameZWDVWQQrdZ1QQcmdZViewItem#ebayphotohosting
and i want to put these in the back 6x9
buying from here
http://cgi.ebay.com/SOUNDSTREAM-XTS6-9-6X9-200-WATT-RMS-4-WAY-SPEAKERS-NEW_W0QQitemZ9719502693QQcategoryZ14942QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
then the most important these 2 15in
from here
http://cgi.ebay.com/2-SOUNDSTREAM-T4-15-15-TARANTULA-SPL-SUBWOOFERS-SUBS_W0QQitemZ9714000779QQcategoryZ18804QQssPageNameZWD1VQQrdZ1QQcmdZViewItem
and the amp not sure//////it all soundstream i just want to go all around soundstream and the wiring from woofersetc also SOUNDSTREAM
so what do think, i think it will be good enough for me, enough to show off
and the amp????? help need suggestions
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 983
what ohm are the subs?
soundstream makes like 100 amps im sure you can find 1 to match them perfectly.
you are going to need a HO alt, battery, and to upgrade ur big 3 wires. so save some money for that.
Post Number: 138
it is a 1 ohm voice coil
and yeah i got a yellow top battery imstalled already i just need the HO alt
should i go with a mono amp or a two channel, and i dont want to power them to each a amp, just one amp because i might hook my compenents to an amp too,,,,dont want to drain to much power know what i mean
Post Number: 140
come on Chauncey, B, rovin, polo, wreak havoc, normal people that are on here what do u think
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 6782
have u heard those comps?? Do u have a soundstream dealer near ur house or something..Why do u only want soundstream, are they sponsoring u???
Username: Nypdlapd
Ontario Canada
Post Number: 357
how much for amp??? do u want a cap???
Post Number: 141
no i just like the designs and the peformance,, i heard they were very good
Post Number: 142
no more than 350 for the amp and yeah the packege cmes with a cap
Username: Nypdlapd
Ontario Canada
Post Number: 359
amps.........
http://cgi.ebay.ca/SOUNDSTREAM-PCA2000D-2000-WATT-CLASS-D-MONO-AMPLIFIER_W0QQite mZ9719096295QQcategoryZ18797QQrdZ1QQcmdZViewItem
Username: Nypdlapd
Ontario Canada
Post Number: 360
thats the best one i THINK is on e-bay
Username: Nypdlapd
Ontario Canada
Post Number: 361
and for the price it puts out 2000 watt rms at 1 ohm or 1500 at 2 ohms
Post Number: 143
thanx i can hook up two subs to that right...big help
Username: Nypdlapd
Ontario Canada
Post Number: 373
yea
Username: Rovin
Trinidad & T...
Post Number: 7603
well honestly - i think u should 4get about ANY 6x9s in the rear it will totally spoil ur front stage & with the $ saved get the very besy u can afford 4 ur fr comps & amp 2 power it .....
Post Number: 144
yea alright i could do that,,, and i re thought it over maybe i should get two 15in RE sx,,what are the prices for the 2005 sx..plus i thought i might need the 6x9s to get better sound so i can hear the words from the song.. will the comp do that Rovin thanx a lot
and im sure the sx's will be better
Username: Shortysetnies
Post Number: 63
If you notice on the link that Nypd-Lapd posted, the box in the pic says 2000 watts MAX but everything the seller put says 2000 watts RMS.
Username: Rovin
Trinidad & T...
Post Number: 7622
if u intend 2 get 2 SX then that SS amp would power them enough - u need like a kicker kx2500 .
SX only come in 2ohms dvc - s figure it out using this guide
http://www.the12volt.com/caraudio/woofer_configurations.asp
i hope u know u will need serious serious current too
http://www.wickedcases.com/caraudio/charging.html ....
Post Number: 146
alright that kicker amp is pretty expensive, ill see what i can do though i got connections i can probaly get it half off thanx again.
and one more question if i do get that amp it sayd 1 channel how would i hook up the second subwoofer??????
and dont give me a web page please
Post Number: 147
anybody
rovin
anybody!!!!!!!!!!!!????????!?!?!?!?!?!?!?????????????????????!!!!!!!!!!!!!!!!!?? ?????????!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!??!?!
Username: Dustin3
Tigard, Or U.S.
Post Number: 987
you just hook it up. lol.
Username: Dustin3
Tigard, Or U.S.
Post Number: 988
you just hook it up to the bridged terminals on the amp, and hook the sub up like above^^ - thats if you have the DVC 2 ohm subs
Post Number: 148
o thanx alot im a little bit up a newb as u can see
ive looked at that before too,just never looked at it like that before
Username: Dustin3
Tigard, Or U.S.
Post Number: 991
you'll be very happy with that set-up. how much r u gettin that amp for?
Post Number: 149
probaly for about 450$ i got to ask this guy i know...and dont ask how he gets the connections,,,it is my fathers friend at work he works in a manufacturing company???dont ask !!lol
SO final setup
1.)soundstream component set front
2.)amp for that
3.)2 RE sx 15in
4.)kicker kx2500.1
5.)nice amp kit
6.) HO alt
7.) low rms speakers for the back..COMPONENTS WILL DO ALL THE WORK
8.) addition blue neon lights inside that pulse to the beatiful and phenominal bass, at the same time matches the anamations from my oel blue head unit (have)
9.) and im golden
Now that (sounds good to me?!?!?!?!?!!!)
Username: Dustin3
Tigard, Or U.S.
Post Number: 1002
very well done. great choices. you will be bumpin ur music the loudest on ur block.
PICTURES!!
Post Number: 151
give me about 1 to 2 months and ill have it all installed
and ill post pics too of my progess like when the subs come in and the amp.
the speakers will be first in the next two weeks ill have those installed
i cant wait to shut up those kids that think there system is the bomb...most of them are my friends lol
and thanx basman and rovin my system is dedicated to u guys.
Username: Rovin
Trinidad & T...
Post Number: 7627
Post Number: 152
Rovin or basman
one more final question are they still selling the 15in RE sx 2005, or just the 2006 now and how much 400$ each right
i want to order them first after the components
Username: Rovin
Trinidad & T...
Post Number: 7634
what i read - 2005 xxx been sold out like 6mths ago & new 2006 is about $600 .
U know SS is ok but u could have gotten some better/cleaner comp speakers like focals/ID/MB quart etc , but its of course more $$$......
Post Number: 153
not the xxx the sx
Post Number: 154
and also then whats another better component set for under say 230$
61/2 comps too
Post Number: 155
rovin?????????????????????/
any???????????
Username: Rovin
Trinidad & T...
Post Number: 7638
well id ont think they upgraded any sx series (unless im wrong)
well $230 - u better search ebay 2 c what best u can get .....
Post Number: 158
alright thanx ill post the website when i find something
Post Number: 159
ROVIN
Focal
http://cgi.ebay.com/FOCAL-ACCESS-165A1-6-1-2-COMPONENT-CAR-SPEAKERS-A1-NEW_W0QQi temZ9718979980QQcategoryZ32819QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
this sound good
http://cgi.ebay.com/FOCAL-165V1-POLYGLASS-6-1-2-COMPONENT-SYSTEM-BRAND-NEW_W0QQi temZ9719392191QQcategoryZ32819QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
then this one
CDT
http://cgi.ebay.com/CDT-Audio-Classic-6-5in-Component-Set-NIB-CL-6_W0QQitemZ9721 167263QQcategoryZ32819QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
MB quart
http://cgi.ebay.com/MB-QUART-PCE-216-Component-System-6-1-2-6-5-PCE216-NEW_W0QQi temZ9718507033QQcategoryZ32819QQrdZ1QQcmdZViewItem
a lot on mb quarts ROVIN
whats the best cdt or focal
prices are good too what do u think,im leaning towards that cdt it has more rms wattage over the focals
Post Number: 160
so which ones rovin if u relly want me to get a better set
thanx
