What head unit preamp???
Username: Sgerard
Post Number: 20
I have an audiobahn a8000t amp. 800rms watts and 2 12" subs. Im wondering what preamp volts of a head unit i should get to get good output from my amp. Is 4 pretty good, or should i go higher like 5 or 6.5!!?
Username: Ctmike
Ct.
Post Number: 389
the higher the better.
Username: Sgerard
Post Number: 22
duh
Username: Ctmike
Ct.
Post Number: 392
just trying to give you some advice by answering your question, don't want none don't ask questions you seem to know the answer to already.
you can go with 4 and be perfectly happy, thats just about the norm for preamp volts. most premier have about 5-6.5volts, and eclipse run up to 7 or 8 i think. either way you go you'll be good, just depends what hu you want.
Username: Sgerard
Post Number: 25
ok thank you
Username: Thomas_g
NM
Post Number: 335
Dont know much bout HU's but i need 1 what about the Pioneer DEh 1700 or 1800? Like 2.3 volts or sumthing.
Username: Ctmike
Ct.
Post Number: 394
it'll work just remember to set your amps input to the same as the hu's output.
Username: Thomas_g
NM
Post Number: 336
2.2 volt my bad. Would it be ok to get a deck that puts out 2.2 volts for the preout voltage? Thanx.
Username: Thomas_g
NM
Post Number: 337
Just read ur post now ctmike, what do you mean by that? How do i set it? On my gain? What if the gain has no #'s on it? Thanx man....
Username: Thomas_g
NM
Post Number: 338
Why do those lineout converters suck behind the factory deck? Or what ever their called. About how much voltage does it put out? Thanx.
Username: Ctmike
Ct.
Post Number: 395
on your amp if their aint numbers it should at least have a range. like right now i'm running 2 pg 400.1 and they don't have every number on it just a range from something like -2 to 8 so i just slowly turned it up to where it would match my prevolt outputs. you'll probably be able to tell because you'll hear the difference as you tune it.
Username: Thomas_g
NM
Post Number: 339
Kool thanx ur a big help man just 1 more question plez, if i buy that pioneer deck what else would i have to buy to connect it and stuff besides the part where my factory deck is huge and i need to put a frame that fits? Thanx....
Do you think the deck comes with wires too? Do i need to buy any wires?
Username: Thomas_g
NM
Post Number: 340
ctmike i just found a panasonic deck that has subwoofer/rear/front pre-amp outputs and puts out 2.5 volts (rear). Should i get this deck instead? Thanx man.......!!!!!!!
Username: Ctmike
Ct.
Post Number: 396
other than the indash kit you should only have to buy a wiring harness kit, which shouldn't run you more than about $15.
Username: Thomas_g
NM
Post Number: 343
Panasonic deck?
"ctmike i just found a panasonic deck that has subwoofer/rear/front pre-amp outputs and puts out 2.5 volts (rear). Should i get this deck instead? Thanx man.......!!!!!!!"
Username: Juliob
Santo DomingoDominican Re...
Post Number: 564
panasonic is kind of cool , but their HU are not reliables, go with premier if you can
Username: Thomas_g
NM
Post Number: 351
Cant. I can either go with a panasonic, a pioneer deh 1700 or a pioneer deh 1800......
Username: L_stay_fly
Morgan city, LA U.S.
Post Number: 33
i have the Pioneer Premier DEH-P860MP Preout Voltage & Impedance Hi-Volt (6.5V), 100 ohms...love this deck....built in eq...nice
