How can I modify this box to meet the HZ on this box?
Username: Bradgman
GAlVeStoN, Tx Usa
Post Number: 186
Would this box be good for the CVR 12"? http://cgi.ebay.com/SINGLE-12-SLOT-PORTED-VENTED-SUB-BOX-3-4-MDF-NEW_W0QQitemZ97 20421164QQcategoryZ50568QQrdZ1QQcmdZViewItem
cvr specs below for the SPL/Deep Bass
2.25 ft3 (63.7 L) + port displacement
3" x 12.5" port, 20.5" long
(7.6cm x 31.8cm port, 52.1cm long)
Power Handling = 300W RMS
Username: Jprix82
Post Number: 544
To lower the tuning freq you make the port lenth longer and to higher the tuning freq you make the port lenth shorter
Username: Terry6405
Sullivan, IN US
Post Number: 713
heres a fair warning, if they dont list the tuning frequency, they probably dont know, which means that they dont know much about box building, and you could build a better one custom for your setup for like 15-20 bucks less
Username: Sploosh56
Ohio
Post Number: 1263
http://www.freewebs.com/wahlsboxes/
