Loud bass pop from sub after car turns off, why?
Username: Bradgman
GAlVeStoN, Tx Usa
Post Number: 163
Does anyone know why the sub makes a loud bass pop right after I turn my car off? Is it the RCA's or the Ground?
thanks
Brad
Username: Night_mirage
AmmanJordan
Post Number: 276
its RCA ..IT happened with me .. and i changed the RCA .. its gone ..
Try better RCA .
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 2805
it could also be that your amp doesnt a good 'soft turn on' circuit. lower end amps get that pop sound went the HU powers up or down.
Username: Sweatyogre
Erie, PA USA
Post Number: 89
I had that problem, until I put a toggle switch on the remote power wire and turned off my sub before my HU.
Username: Rideredder
Cornell, IL USA
Post Number: 290
I installed a system for my friend and it did that too. He was using a BD series RF amp with soft turn off and Monster Cable RCA's. His would do it when you turn it on, off, and whenever he changed the radio station or CD.
Username: Alteraudiousa
Concord
Post Number: 723
usually its either the amp or the HU itself. I know the Eclipse 8443 was notorious for having a pop off. Whats your HU?
Username: Extremesound1
Coventry, RI United states
Post Number: 145
whats ur head unit pioneer??? my friend does that to he has a powerbass and and hits at the end when he turns off the car too, and his amp is a jl 1000/1 i think it is the head unit.
like the beeping from the head unit of a pioner when u shut it off (mine does that), i think the bass does that maybe also
Username: Ucfsaxman
Oviedo/orlando, Fl
Post Number: 756
usually that happens when you still have a stock HU if you don't have a stock Hu then that is definately very odd and shouldn't be happening.
Username: Bradgman
GAlVeStoN, Tx Usa
Post Number: 167
Its a kenwood X890 with the usb attachment. Its one of the better kenwoods.
Username: B101
Queen City, NC USA
Post Number: 2700
lol, what kind of amp is it??
the problem is actually the amplifier 90% of the time...
example my prd1000.1 gave a loud boom, when turn the key straight off.. the boom is the extra voltage on the amplifiers voltage rails leaking out of the capacitors to the subs..
my 2 2500ds do not give me that boom!!
you can wire a relay to the remote wire, to fix this problem..
