Kicker..question for the experienced
Username: Blainew
Post Number: 1151
if i get two kicker L7's and put them to the recommended sealed enclosure size....would an orion 2500D be alright to power them. for two .. the RMS would be 1500 watts but considering box impedance rise, wouldnt the amp not give out the full 2500 watts
would it be a mistake to use the orion 2500d??
Username: Jmloughrey
Farmington, CT
Post Number: 1516
i personally think the 2500d would be too much amp for those subs.
the 1200d would be a better bet.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 6814
https://www.ecoustics.com/electronics/forum/car-audio/221182.html
Username: Blainew
Post Number: 1155
but take into consideration box imp rise
wouldnt the 2500D be okay if were just carefull with it?
Username: Blainew
Post Number: 1156
chauncey i would be interested in that amp but im not doin this for a while i need to get all the $$
Post Number: 6815
how long is a while.lol
Username: Blainew
Post Number: 1158
well not in the next 5 months...i really dont know
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 2824
L7 + sealed box = waste of a sub
IMO
you may want to just go w/ 1 sub in a good vented box. just my $0.02
Username: Blainew
Post Number: 1160
i want the bass to be like quick and sharp....not VERY BOOMY
isnt vented more boomy
Username: Van_man
Boston, MA
Post Number: 119
I do not like my L7 12, I just installed mine this weekend and will be taking it out and selling it and the boxtuned to 30HZ... It sounds terrible, Like a cat is stuck in the basket scratching to get out.... there may be a problem with it inside. Each coil is still at 2 ohms on DMM. and have continutity so I know there not blown... Anyway I going for 2 SWR1222D instead...
Username: Blainew
Post Number: 1161
i like how the kickers sound..i thought they sounded good
Username: Redliner
Wilmington, Ma
Post Number: 1694
"i want the bass to be like quick and sharp....not VERY BOOMY "
then the l7 is not for you lol
Username: Van_man
Boston, MA
Post Number: 121
this is the second l7 this year i had probs with
