Pioneer DEH-P860MP no inputs????????
Username: Pvduk
Post Number: 41
Hi,
I've been looking to buy a Pioneer Premier deh-p860mp, but have recently noticed it doesn't seem it have inputs of any kind.
Can someone please verify this.
I would want to connect up my laptop or any other portable music device!
This would be such a shame if it didn't have one!
Username: Pvduk
Post Number: 42
P.S. If it doesn't have inputs, could someone suggest a near same spec headunit which does,, please :-)
Username: Pvduk
Post Number: 43
Come on guys, I know a lot of you have these units. Pretty please :-)
Username: Phlipcyde
Palmer, Alaska United States
Post Number: 11
It looks like according to pioneers website that you need some sort of adapter to get an aux input for the p860mp. The new premier units such as the p780mp and p880prs do have an aux input, they are a little more expensive than the p860 but according to initial reviews they are worth it.
Username: Illuminator
Post Number: 2953
If it doesn't have any RCA inputs, then indeed, it will need an external adaptor. Most Pioneer head units are built that way. The adaptor will probably hook up to the unit via the CD changer input.
Username: Pvduk
Post Number: 44
Thanks guys.
Pioneer have the CD-RB20 which is like an external box with own power supply. (more expensive)
Then theres the CD-RB10 which is a bare adaptor cable.
Does any of you guys know the difference in sound quality input to the headunit???
Username: Tafkam
Texas
Post Number: 304
I have the D-RB10 with the exact same HU which I am using with Sirius radio, hard to tell about the quality as I expect some lesser level of quality from any aux source but it sounds pretty good ( the sound level is not as loud as radio or cd and the quality is not the same as cd but I guess that is to be expected)
Hope that helped that is just my personal experence.....
