OT- Amp Kit
Username: Mateo
Post Number: 70
ok i know im in the wrong forum but i couldnt get any anwsers in the others and this is where most of the people are most of the time. my quesiton is does an Amp Kit contain everything (as in wires etc.) i need to hook up a system? thanks in advance
Username: Maniac
Post Number: 67
yes it does it comes with everything you need
Username: Goatin
U.S.A
Post Number: 889
You Need:
4 or 8 ga wire
a channel wire
an A/V wire
a 4 or 8 ga ground wire
And some come with
speaker wire
a black sleve to hide your wires
and a few wire ties
I bought my 4 ga wiring kit on ebay for $30 it had everything I just said.
Username: Mateo
Post Number: 71
ok thanks alot guys for the quick responses. and whats the difference between platnum and 24kt plated wires. i know platnum is better in terms of rings and such. can someone explain this to me. thanks.
and i was thinking one of these
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3563
or
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3562
what do you guys think. thanks for the quick responses.
Username: Winterfreshpimp
Chisago, MN America
Post Number: 192
if im not mistaken wich i prolly am cause it makes no sense i heard silver was the best conducter of electricity..... what kinda of amp do you have...?
Username: Drivingreckless
Near tampa, Florida United state...
Post Number: 160
GO ON EBAY YOU WILL FIND THOSE TO CHEAPER B/C I HAVE BEEN LOOKIN FOR AN AMP KIT ACTUALLY U CAN GET A DUAL AMP KIT 0 GAUGE FOR 106+S&H LOOK
http://cgi.ebay.com/0-GAUGE-DUAL-AMP-KIT-CUSTOM-CAR-AUDIO-STEREO-WIRE-NEW_W0QQit emZ9718487624QQcategoryZ79815QQrdZ1QQcmdZViewItem
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 2714
many amp kits dont come with EVERYTHING. some dont come with RCAs, and if they do they may be complete junk. some miss something here and there. but your basically getting about everything you need.
and between platinum or gold. doesnt matter. they will conduct electricity great either way. i get platinum just because i like the blue and silver look.
Username: Dustin3
Tigard, Or U.S.
Post Number: 990
i buy all my wires from:
http://www.knukonceptz.com/
its a great place, and the amp kits do come with everything and are very good quality :-)
Username: Mateo
Post Number: 75
ok thanks everyone. i was just using those two as a reference. but thanks again that cleared alot up for me.
