Bronze Member Username: HockeyknightPost Number: 59 Registered: Apr-06 | k i think i finally made up my mind no what kind of box would u put this in (size and type) im only running 1 15 cvx. let me know what u think http://www.onlinecarstereo.com/CarAudio/ProductReview.aspx?ProductID=14965 http://www.etronics.com/product.asp?stk_code=kic06cvx152&store=&catid=370 |
Silver Member Username: GoatinU.S.A Post Number: 894 Registered: Jan-06 | If you have the bank I would get a tcab box, they build awesome box's. |
Silver Member Username: GoatinU.S.A Post Number: 895 Registered: Jan-06 | oh and ported you want a ported box with that. |
Bronze Member Username: HockeyknightPost Number: 60 Registered: Apr-06 | whats the tcab |
Bronze Member Username: HockeyknightPost Number: 61 Registered: Apr-06 | i was more thinkin on the lines of buildin my own im low on space and the ideal outside dimensions would be 36"(w)x12"(d)x16"(h) |
Silver Member Username: GoatinU.S.A Post Number: 898 Registered: Jan-06 | Well maybe you sould get A 12 then because MDF is 3/4" thick so top + bottom =1 1/2" 16" - 1 1/2" --------- 14 1/2" or you will need a taller box. |
